Orbi WiFi 7 RBE973
Reply
ORBI RBK50v2 BEST WAY TO SETUP?
Xx-Shadowz-xX
What is the best way to setup the ORBI RBK50v2 after doing a factory reset? Setup by connecting to PC or Setup by using the ORBI App from Apple Store using IPhone?
Message 1 of 4
CrimpOn
Guru
Re: ORBI RBK50v2 BEST WAY TO SETUP?
Assuming that you want to configure the system*, most people who are active on the forum prefer to use the web interface over the 'app'. (by far).  In addition, most of us "old timers" prefer to use a computer (PC, Mac, laptop) that is connected with an Ethernet cable to the router.
* If you are comfortable using the WiFi name (SSID) & password printed on the label and have nothing else to configure, the system will function perfectly well without any 'setup' at all.  Many of us elect to have the WiFi system use the exact same SSID/password as all our devices already know about, which means the system has to be configured.
Message 2 of 4
KevinLiT
NETGEAR Moderator
Hello Xx-Shadowz-xX,
In my experience, the best way to set up a new Orbi system is by using the Orbi App. The walkthrough guidance allows you to customize your network. Therefore, once you are done with the setup process your network is ready to go.
Using the Web GUI is preferable when you know exactly where to go to manipulate the settings desired for your network.
Cheers!
Kevin
Community Team
Message 3 of 4
MarkRamos
Couple of options,
Configure the modem for transparent bridge or modem only mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 635 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
