× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
ORBI RBR20 covd lock up disaster. I've got this aweful piece of gear and no support $$ for help.
BenZen
ORBI RBR 20 mesh network.  Also have nighthawk  R7000.
Am on day 25 of isolation and the orbi network has been an absolute disaster to get going.  Unfortuntately i cant get anyone in to sort it or buy anything to replace it right now as the whole country is in lockdown.
]I'm getting the 404 and 401 errors to the point it's really effecting productivity.
Also need to install some more sonos speakers (have some set up already).
If someone has expertise and can help get this sorted, am happy to pay for your time.  I'm techy enough to follow instructions.  but not to hold the details of how this **bleep** works.  and have no ambition to become an expert.
great concept but not worth the aggravation in my opinion.  if you can help please let me know.
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 7
Guru
Re: ORBI RBR20 covd lock up disaster. I've got this aweful piece of gear and no support $$ for hel
Start at the basics.
1. What modem are you using?
2. What firmware is on your orbi?
3. You put you have the orbi and the R7000. Are you using them at the same time? If so is one of them running in AP mode (access point).
4. What firmware is on the R7000?
Message 2 of 7
BenZen
Hi - I'm looking for someone who can get on a call and work through things with me.
Hve been down this road trying to sort by text with no joy.
I have fibre coming into an old modem, it then was goin to the nighthawk.  worked perfectly but didnt have the range.
Have tried to run orbi and nighthawk together and seperatley with no joy.
Message 3 of 7
Guru
This is the community forum. We're not netgear. We're members of the public trying to help out.
Start by listing the items I asked for and we can probably help get you up and running.
Message 4 of 7
Guru
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You might want to try option #3...if your using the R7000 has your main router.
ALso let us know the mfr and model# of the ISP modem as well...
Message 5 of 7
BenZen
understand that, I'm happy to pay someone to help.  The time for me to try and do it all step by step with text is just not viable.
Is there anyone who has actually worked this out and has these running with home automation products etc?  Seem to be a complete disaster of a product with the complexity they have and lack of support?
Message 6 of 7
BenZen
thanks - but your not talking english and I have not idea half of what youve asked.
I'm also not able to spend hours reading up on what a double nat is??
Hoping someone has experience and will help who actually knows what they are dong and isnt all guess work.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 770 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
