- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
ORBI RBR50
I've been having trouble with my ORBI RBR50 losing internet connection frequently (several times a week and sometimes multiple times a day). It has the latest firmware update (V2.5.1.8). I do not have a modem and only one satellite. There is a straight connection into the router from my ISP. Any ideas/suggestions? TIA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBR50
Do both wired and wireless connections go down?
Have you ask the ISP to reset there side connection hardware?
Has a factory reset and setup from scratch been performed since last FW update? You might give this a try with the RBR.
Don't enable any Circle or Armor features...
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBR50
1. Just the wireless connections drop. Wired connections are fine.
2. I have not spoken to ISP yet due to #1.
3. At this moment, I am only showing one other wireless network available which shows as a hidden network. Occasionally, I will see a couple of other neghbor networks show up.
I have not tried the factory reset yet. That was going to be my last resort.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBR50
Try a factory reset and setup from scratch. v2.5.1.8 works well for me and others.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBR50
@dmccoy wrote:I've been having trouble with my ORBI RBR50 losing internet connection frequently (several times a week and sometimes multiple times a day). It has the latest firmware update (V2.5.1.8). I do not have a modem and only one satellite. There is a straight connection into the router from my ISP. Any ideas/suggestions? TIA
here's your problem: V2.5.1.8
others meant to mention that
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBR50
What is the Mfr and model# of the ISP modem the NG router is connected too? It would be a good step to start to see if the RBR can be come stable. It's a valid trouble shooting step that needs to be tried.
Try a factory reset on the RBR and RBS and setup from scratch. Try some of the suggestions as well.
@dmccoy wrote:
Here's another thing I totally forgot to mention. The router loses internet connection but the satellite does not. See attached screenshot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBR50
@FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
Factory reset is NOT required.
A better FW is.
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
