Orbi WiFi 7 RBE973
Reply
ORBI Router RBR50
hdunker
Follower
ORBI Router RBR50
I have a 3 unit ORBI WIFI network withan Verizon LTE Tower connected to it for the internet by an Ethernet connection.  When I direct connect to the LTE, everything works fine. But when I connect to the internet through the ORBI, all pictures, example when I access my email, are closed down and just a small window box outline with an x in it is shown. When I try to access GOOGLE, I get a security signon screen. Any suggestions ass to a fix?
Message 1 of 2
Guru
Re: ORBI Router RBR50
What is the model # of the modem your using with the Orbi router? Does it have a built in router by chance?
What IP address is the Orbi router getting from the ISP modem? 192.168.#.### or a ##.##.###.### address?
What FW version is loaded on the Orbi router?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 393 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
