Orbi WiFi 7 RBE973
Reply
ORBI WiFi not Visible
OrbiEd
Putting Model # here as Web site won't allow selecting in correct field. RBR750.
On first setup with app, can't progress as phone cannot see the default ORBI wifi. it's turned on, LED is solid and cat 5e is plugged into internet ethernet port.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 2
Guru
Re: ORBI WiFi not Visible
You might get better assistant (and the model number for that device) in the Orbi AX forum.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Have you tried setting up with a device hardwired into the router?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 424 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
