×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
ORBI crashes with 10gb nic
Brain29
Apprentice
RBR50
I have a few devices with 10Gb nics that support 10/5/2.5/1 Gbps 10/100mbps
The Orbi will work fine for a day then completely lock up and crash if one of these devices is plugged in
I have older routers that are probally 5 years old consumer level 1Gbps that have no issues with these devices
Message 1 of 4
Guru
Re: ORBI crashes with 10gb nic
Can you manually configure the speed of the 10Gb NIC for 1000mb FDX?
Whats the Mfr and model of this 10Gb NIC?
I presume these 10Gb NICs are the issue and need to be looked at. Most current Orbi devices only support 1Gb connections and 1Gb supporting devices.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
Brain29
Apprentice
If just the nics had issues I would agree - but a complete shut down should not happen regardless
its not the nics they are performing at the correct speed - I also use them to test other office/home equpment big and small networks never once have they brougth down an entire network or presented a problem of any kind - which is only happening with the orbi
I also have $20 routers that are 5 years old that have no issue with them
Message 3 of 4
Guru
Did you try and manually set 1Gb connection speeds on these NICs?
What is the Mfr and Model# of these NICs?
Something you might contact NG support about. If these are the only NICs causing this and happens with the Orbi, then there maybe a compatiblity issue between them.
Message 4 of 4
Discussion stats
  • 3 replies
  • 835 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
