Orbi WiFi 7 RBE973
Reply
ORBI logging of ISP outage
ajg617
Is there an option to log ISP outages in the ORBI?  We've been suffering through mulitple short (45 second or so) outages each day for weeks now.  I've talked with Comcast tech support which was futile.  Of note, when this occurs, I seem to lose ability to access other PCs on the LAN - i.e. a file transfer from one PC to another will stop and am unable to login to the Orbi as well.
For example, on 12/8 we lost all internet service a 5:04pm, 5:39pm, and 5:41pm - each lasted less than two minutes.  During those times, I could not login to Orbi or access a mapped drive on another PC.
TIA,
Ajg
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 7
Accepted Solutions
CrimpOn
Guru
Re: ORBI logging of ISP outage
And, yes, there should be local access even if there is no internet.
Message 5 of 7
All Replies
CrimpOn
Guru
I believe the Orbi will log internet disconnections. Try disconnecting the WAN cable. Wait for the ring to turn magenta then plug it back in. See if this appears in the log.
It is not clear to me that loss of internet would cause those symptoms.
Message 2 of 7
ajg617
Yes, the more I think about it, I should still have LAN access even if the ISP drops and I don't.  Can't seem to find a last boot time on the Orbi though.
Message 3 of 7
CrimpOn
Guru
Orbi logs "roll over" and events like that disappear. I have mine set to email the log to me every time it fills up. I can go 100 days without a reboot.
Message 4 of 7
CrimpOn
Guru
Message 5 of 7
ajg617
Do you uncheck any of the logging events?  I get the continuous DDoS logs so I imagine it will fill up fairly quickly.
Message 6 of 7
CrimpOn
Guru
I get an email almost every day.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1527 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
