× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
ORBI satellite worked finefor 6 months and now no power
Jwc065
Follower
it was working fine and then it turned off and won't start back up. I reset like troubleshooting said. I tried moving the satellite. I rebooted everything. I don't want to buy a new satellite or pay for support if I don't have to.
Model: RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 3
Re: ORBI satellite worked finefor 6 months and now no power
Your subject says "no power". Does that mean what is says? The power doesn't get to the satellite? Or is it some other symptom? You can't reset something when it doesn't get power.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
Message 2 of 3
Guru
Did the FW update on the RBR while your RBS was off?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 426 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
