×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
ORBI75
marly51
ORBI75
I have this model and have two extenders for it so that it can penetrate the lathe and plaster walls of my nearly 100 yr old house. I am trying to connect an OHM plug to my fridge but must have enough wifi which I do.  Why can't I connect? The OHM plug helps saves energy, supposedly.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 7
CrimpOn
Guru
Re: ORBI75
Every Orbi leaves the factory with a default WiFi name consisting of the letters "ORBI" plus a two digit number.  The actual product number can be found on the product label on the bottom of the router.
A refrigerator is a huge metal appliance that WiFi signals may have trouble passing through.  By any chance, would the refrigerator lie directly between the OHM device and the nearest Orbi unit?
(Would love to see a URL link to this energy saving gizmo.)
I love my Orbi.
Message 2 of 7
marly51
Re: ORBI75
To the answer of the satellite, it is not in close proximity. I would say it is at least 50’ away from the frig. What would you recommend now? Do I have to get a new system?
Message 3 of 7
marly51
Re: ORBI75
The serial no. Is
MAC no.
Message 4 of 7
CrimpOn
Guru
Re: ORBI75
I think I get it now.  This appears to be part of a program by Pacific Gas & Electric, Southern California Edison, and San Diego Gas & Electric. The customer installs 'smart devices' in the house to control appliances that use electricity and allows the electric company to turn them on and off during specific times of the day.   (See footnote at the bottom of the page: https://www.ohmconnect.com )
Most refrigerators connect to an electrical outlet which is physically behind the refrigerator.  If the metal refrigerator is blocking WiFi signals from the front and the lath & plaster walls are blocking WiFi signals from the back, it may be a challenge to get any WiFi device connected. This has nothing to do with the brand or model of WiFi system. It is radio physics.  There are three things that might work:
  • Connect the Ohm Plug to the 'app' with it plugged into a different electrical outlet where it has a clear view of the smartphone and gets a strong WiFi signal.  After the plug has been configured and is known to function correctly, then move it to the electrical outlet behind the refrigerator.  The plug receives and transmits almost no data at all (just "turn on", or "turn off").  Maybe it will get enough of a WiFi signal to do that after it has been set up with the app.
  • Plug an extension cord into the wall outlet, the Ohm Plug into the extension cord, and the refrigerator into the Ohm Plug.  Use tape or something to place the Ohm Plug somewhere that is not blocked by the refrigerator (on top? to the side?)
  • Get an inexpensive WiFi extender that can be placed where it gets a good WiFi signal and can be 'seen' by the Ohm Plug.  A TP-Link N300, for example, is $16 on Amazon.  WiFi extenders are used quite often for situations where a device that never moves doesn't get a strong enough WiFi signal. (garage door openers, sprinkler controllers, pool controllers, security cameras, etc.)
I love my Orbi.
Message 5 of 7
marly51
Re: ORBI75
WOW! Okay I will try that but not crazy about the extension cord but maybe that would work! Thanks for helping. Really appreciate it.
Message 6 of 7
Guru
Re: ORBI75
So what Orbi model do you have?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 800 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
