× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
OrOOrbirbi
Tirgoman
Follower
OrOOrbirbi
Looking at buying Orbi to replace an old Access Point. Looking at RBK50.
Have 2 questions:
First: Says it supports Guest users, my question does it support more than one SSID and hence they'd have different Passwords. Obviously I want to limit the access that the Guest User has vs the Access that I would have to the network. I noted that it says supports One SSID and also says it supports Guest user, this seems contradictory.
Second question: If an Orbi is "connected" to another Orbi wirelessly can I then plug an ethernet cable into the second Orbi to connect a device to the network.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 3
Roamabout
Luminary
Re: OrOOrbirbi
If you enable the guest network feature it will have a different SSID and its own security options from the primary wifi. It defaults to NETGEAR-Guest, no password required. I would enable one of the stronger authentication options personally unless it was just enabled for an occasion and then turned off.
You sure can plug a wired device into an ethernet port on a wired satellite. I do that to connect an older HP print server in a remote part of the house. Pretty cool feature really.
Message 2 of 3
tsig
Luminary
Re: OrOOrbirbi
You can actually have 2 different guest networks, one for 2.4 and one for 5ghz.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 876 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
