bryanchuah17
Jun 10, 2020Tutor
Orange light for one of the satellite
I would like to ask for your opinion because one of my satellite for my Orbi app it appear orange light. May I know if I plug the LAN cable to the satellite which the LAN cable is connected to many devices. Is it the problem that affected my internet connection became poor (orange light)?
1 Reply
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Not seen on Orbi AX.
