dontdelete's avatar
dontdelete
Follower
Nov 02, 2023
OrbI RBR50
How do I check if my Orbi is current on security?
  • michaelkenward's avatar
    michaelkenward
    Security is in the hands of the firmware that you have installed on your RBR50 and any satellites.
    Netgear tries to help with its on=board checks for firmware updates. Unfortunately, these are not as reliable as they could be, sometimes missing out on newer version.
    The best guarantee is to check the support pages for your hardware.
    Support | NETGEAR
    That page will have a library of all the available versions of firmware for your device.
    Compare the firmware version installed on your router with that list.
    If you don't have the latest and need to update it, read the release notes for the new version or follow this:
    How do I check and manually update the firmware on my Orbi satellite? | Answer | NETGEAR Support
