×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Orbi: Automatically adjust for daylight savings time ISSUES
machaf
Follower
When I have Automatically adjust for daylight savings time checked in the router it screws up traffic meter and the VPN connection.
Traffic meters reads 0
VPN connections constantly drop and is unstable.
I cannot use Remote Desktop. Connections seem to constantly drop. I'm running the newest firmware "V2.3.1.44"
If I leave "Automatically adjust for daylight savings time" unchecked. Everything works properly.
Message 1 of 4
Chuck_M
Mentor
Re: Orbi: Automatically adjust for daylight savings time ISSUES
Can you please compare the traffic meter results between the phone app and the web gui?  Mine appear different -- and I dont have DST enabled.
My Equipment: Cox Cable (350Mb/35Mb), Orbi AX6000 (RBR850, 3 x RBS850) (2xWired backhaul), NG GS116PP Gigabit Smart Switch, Synology DS1019+ NAS
Message 2 of 4
randomousity
Luminary
Just came across your post and decided to check my settings. I had automatically adjust for daylight saving time checked, and have noticed that the traffic meter is useless, showing next to no usage, and only for last month. So I unchecked to automatically adjust for DST, and then looked at the traffic meter again, and, lo and behold, the usage volumes for all time periods seem to be about what I'd expect them to be.
They do all say 0:0 for connection time, whether it's checked or not, but I don't know if that's just how it displays for a constant connection. But so odd to discover that a time setting is affecting the traffic meter display.
My Setup | Internet via TC8715D Cable modem, Bridge Mode, 200↓ 10↑ | Wifi Router Orbi RBK50 AC3000, Router Mode, Wireless Backhaul
Message 3 of 4
neerajv
Tutor
Everytime after few hours, the settings automatically gets checked and then stats become zero unless i again uncheck it.
Looks like netgear is aware of the issue but has done nothing since last 1 year.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Traffic-meter-DAYLIGHT-SAVING-TIME-BUG-R7800...
-Neeraj
Message 4 of 4
Discussion stats
  • 3 replies
  • 1498 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 6E
