- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Backhaul Ethernet Switch
- Mark as New
- Bookmark
- Subscribe
- Permalink
Currently when I connect the RBS50 satelites via ethernet to a switch that has other devises, my network goes crazy. I loose Wifi on some devises and others I lose internet connection (but maintain local network conection).
I use an unmanaged Netgear switch but have other devises on the same switch. Do the staelites need their own switch? Or can other devises be on the switch too?
Thankyou,
Jamie
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Backhaul Ethernet Switch
Other devices can be on the switch. I've got quite a few on mine.
What modem/gateway do you have?
What firmware is on the orbi?
what other devices are connected to the switch?
What actual switch is it?
How is your network wired up?
for example see my signature.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do you have the RBS and switch connected to the RBR?
How long after you connect the RBS to the switch are you waiting for the RBS to sync fully?
@jamepc wrote:Currently when I connect the RBS50 satelites via ethernet to a switch that has other devises, my network goes crazy. I loose Wifi on some devises and others I lose internet connection (but maintain local network conection).
Thankyou,
Jamie
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem: Arris TM1602a
Netgear Switch GS116NA
Orbi FW v2.7.2.104
Also on switch:
2 Vonage VOIP devises
3 Windows PC's
1 Security DVR
Modem> Orbi Router> Switch
Thanks for any help!
Jamie
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jamepc wrote:Currently when I connect the RBS50 satelites via ethernet to a switch that has other devices, my network goes crazy. I loose Wifi on some devices and others I lose internet connection (but maintain local network conection).
I use an unmanaged Netgear switch but have other devices on the same switch. Do the staelites need their own switch? Or can other devices be on the switch too?
Is "currently" significant? i.e. was this configuration working before?
Yes, other devices can be on the same switch as the satellite.
Is it correct to assume that the swtich comes after the Orbi, i.e.::
Internet modem port connected to WAN (yellow) port on Orbi.
Orbi LAN port connected to switch.
Satellite and other devices connected to switch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If your vonage devices aren't connected, do you have issues with other devices connected?
I've seen where some VOIP phone setups host their own dhcp server and it can cause issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be aware of this:
@jamepc wrote:Modem: Arris TM1602a
Orbi FW v2.7.2.104
Also on switch:
3 Windows PC's
1 Security DVR
Jamie
- Mark as New
- Bookmark
- Subscribe
- Permalink
I beleive everything was fully synced since I got a solid blue light for a while and it remained wired up for at least 30 minuets before I had to go back to wireless backhaul.
One of the RBS50's is still on v2.0.0.74 and syas "update failed". All the other RBS50's are on v2.7.2.104.
I have an RBS40 thats on V2.6.2.104 but it says "No new firmware available".
Is it ok for the one RBS50 to be on different firmware?
And the RBS40 only goes up to V2.6.2.104?
Should they all revert to a known good working firmware?
I'm going to try it without the Vonage devices connected once the network isnt in use.
Thanks again,
Jamie
- Mark as New
- Bookmark
- Subscribe
- Permalink
NO, all RBS should be on same v104 FW.
40 series uses v2.6.x for it's model series while the 50 series is on v2.7.x. Though the recent version is v104 so this should be ok as v104 is most current for both series. You might turn this one OFF and just test the 50 series after you get the one RBS50 updated manually to v104.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Manually updated the one RBS50 to v104 ut unaboe to test wired backhaul until the weekend when network use is minimal.
Is having mixed FW versions a known issue for wired backhaul?
When I downloaded 2.7.2.104 I saw that they are also offering 2.6.1.40 as a download option. Is that because there's a lot of people experiencing issues with v104?
Thanks again,
Jamie
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jamepc wrote:When I downloaded 2.7.2.104 I saw that they are also offering 2.6.1.40 as a download option. Is that because there's a lot of people experiencing issues with v104?
I have never seen an explanation from Netgear for there being two firmware versions for the Orbi. At one time, there were separate versions clearly labeled for US and "world", hinting that some feature was available in one part of the world and not in the other. This started last summer (2020) about when Netgear began promoting their "Netgear Parental Controls" to replace Disney Circle.
Netgear provides almost zero practical information to customers. (opinion)
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
