- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Behind Vonage
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi Behind Vonage
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Behind Vonage
Modem Combo Units: Your best option would probably be #3...
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would have used the routers DMZ with the Vonage IP address in the DMZ of the router. This would help with Vonage behind a router. I have my microcell behind a router and use the DMZ for the microcell. Works well.
Up to you.
