- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi CBR40 Dropping Internet Connection Multiple Times Throughout the Day
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi CBR40 Dropping Internet Connection Multiple Times Throughout the Day
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's the event log from the most recent drop. Again any help would be appreciated. I really don't want to have to buy a new router/modem right now but can't continue resetting and waiting several minutes for the modem to reboot 2-3 times daily. Also, I have two satelites connected wirelessly. One is in my garage and other in my kitchen. Each is 20-30 feet from the CBR40 and they are probably 40ish feet away from each other forming a triangle. The kitchen satellite is an RBS20 and garage one is an RBS50. I originally had just the RBS20 but added the RBS50 last summer and have been using this setup for nearly a year without issue.
Jun 23 2022 14:36:31 Warning(5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jun 23 2022 14:36:31 Notice(6) TLV-11 - unrecognized OID
Jun 23 2022 14:38:29 Warning(5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jun 23 2022 14:38:29 Notice(6) TLV-11 - unrecognized OID
These messages are all over the event log for the last 8 days (only shows last 8 days of events). Another one that shows up periodically is
Critical(3) No Ranging Response received - T3 time-out
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is that the log from the router? I don't recognise the format.
You are on a cable Internet service. There are people around here who are much better informed on that front. They can help you to unravel the connection data. That is often a source of problems. Your ISP may say everything is fine at its end, but a lot can happen between the ISP and your device.
That is why I suggested getting your message out of the router zone and into an area where people understand cable modems.
With luck someone like @plemans will see your message and step in.
That the modem/router worked for four years certainly suggests that there is something happening outside the device.
You say that you reset the modem through the ISP. Have you done a local factory reset?
- Mark as New
- Bookmark
- Subscribe
- Permalink
A full screen snip of the event log and the cable connections page helps the most for checking the line.
But a few tips for troubleshooting cable coax lines.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your signal is actually a bit hot (high).
Try putting a good quality double or triple splitter in line to cut the power level down.
You should be between -7.5dbmv to 7.5dbmv. You're a ways above that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
10db attenuator is quite a significant jump. You can try it but make sure to take the double splitter out. Normally, I'd rather see the signal on the high side versus low side. reason why is if the downstream is high, it usually means the hub is closer to the home and so it doesn't take the modem as much power to communicate with it. If you're to low, it means its further away and the modem has to increase its output power to compensate.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah, the logs are still showing connection issues. You might have to have the isp check the line.
Again, direct connect it to where it comes in just to ensure it isn't an issue inside the home as many ISP's charge if the wiring is internal to the home.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It looks good externally. but I've seen poor crimping/stripping jobs where the shield was touching the copper coax line though. so even though it looks good, externally, sometimes you have to check all the connections. But if the issue is outside the home, its on the ISP.
I've actually had to rent a modem before to prove to an isp that it wasn't the modem as they wouldn't troubleshoot anymore without charging me for it. Not saying 100% it isn't the modem as a hardware issue with the modem could give you errors too, its just something I've had to do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah those power levels are pretty spot on perfect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
tough to say after that little time. A few errors isn't a big deal, its when its constant and that number grows consistently. Ideally you'd like zero but again, a few isn't an issue
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
