Computer_geek21's avatar
Jun 09, 2020
Orbi CBR40 can't find SSID.
Hi all,
I recently performed a factory reset on my Orbi CBR40 router/modem. All 4 blue LED's are lit up and solid, and the ring LED located on the top is a pulsating white. When trying to setup the router through the Orbi app, it has me scan the QR code which works, ensure it's plugged in properly, but cannot actually find the network to connect to. The SSID on the physical router is called Orbi14 but is nowhere to be found on either mobile devices nor on the laptops in the house. Any ideas? I thank you for your time.
1 Reply
  • FURRYe38's avatar
    Can you connect a wired LAN cable PC to the back of the CBR40 and use a web browser, walk thru the setup wizard at 192.168.0.1 or it might be at 192.168.1.1?
