Orbi WiFi 7 RBE973
Reply
Orbi - Can't connect or update satellite-2 firmware - Router and Sat-1 versus Sat-2 version issue
ReadyMark
Tutor
I have RBR50 router plus two RBS50 satellites. I have been running with only 1 satellite for about a year and now need to add the 2nd satellite. I tried to add the satellite but it won't connect. Magenta satellite ring when I tied to sync and admin info says backhaul "Poor" and connection type 5G. I've tried to connect in troubleshooting a few feet from the router to eliminate distance issue. After troubleshooting I realized the router and sat-1 were on firmware v2.21.210 and the older "new" satellite was still at oringinal v1.20.6
I tried to do manual update. I downloaded the current firmware RBS50-v2.21.210.img from Netgear site but each time I try to update I get message "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
I have tried this many times with no success. Any suggestions?
I am using mac osx 10.12.6
Kind regards,
Mark
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 6
Accepted Solutions
Guru
Re: Orbi - Can't connect or update satellite-2 firmware - Router and Sat-1 versus Sat-2 version issu
What you need to do is download a middle of the road version of FW for the Satellite, try RBS50 (Orbi Satellite) Firmware Version 2.0.0.74.
If you can get the middle of the road version loaded, then manually apply the v210 version to the satellite. It should take this time.
Message 2 of 6
All Replies
Guru
Message 2 of 6
ReadyMark
Tutor
Thank you. I will try that. I have read many of the posts and did not see that suggestion prior. I was wondering if I had to go incrementaly up in the FW updates until reaching the current.
I will report back if that works to be of help to others.
Cheers
Message 3 of 6
Guru
It should. Smiley Wink
Message 4 of 6
ReadyMark
Tutor
Many thanks for the solution of using the incremental approach of updating to RBS50 (Orbi Satellite) Firmware Version 2.0.0.74.
That worked perfectly and then synced up and fully updated to current version. Entire network is now working wonderfully.
Thanks for the help.
Message 5 of 6
Guru
Enjoy. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3530 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
