× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Orbi Ethernet Backhaul
flatfoot139
Follower
Hello,  I have the Orbi RBR40 router with 1 satelitte that is currently connected through wifi.  The Satelitte is not getting a strong signal due to the layout of the house (concrete, walls etc...).  I attempted to move it to a different location and the weak signal continued.  The satelitte is in a part of the house where extended range is needed. Would hardwiring the satelitte from the router improve the satelitte's signal?
Message 1 of 3
Mstrbig
Master
Re: Orbi Ethernet Backhaul
How many Sq Ft is your home? Depending on size and layout, you have 2 options:
1: Add another satellite
2: Hardwire the satellite and you will get good coverage around the satellite broadcast area.
Message 2 of 3
Guru
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 403 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
