- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Firmware 2.3.1.60
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Firmware 2.3.1.60
@Joboo7777 wrote:
I think issues people may be having go beyond the advance settings. I would suggest also including the following non default settings:
Are you running Armor?
Are you running guest network?
Are you running separate SSIDs for 2.4 and 5?
Are you running Disney Circle?
Do you set wifi channels manually?
Basically need to capture every setting that is outside the default. Which for some could be quite a few. Regardless of what it is or how insignificant you may think it is, it's important to capture these to identifty a pattern.
Then there are environment variables that are alittle harder to capture. How many wireless networks are you competing with in your neighborhood, etc.
Yes, that's a good point.
Assuming Backhaul link/signal between Orbi Router/Satellite is rock solid, the one Wireless setting, which is most interesting to me is "Preamble Mode". By default it is set to Auto. That one setting has a significant impact on Wireless clients. Auto might not be the best choice if I have a mixed of clients or weak signal to one of the clients. A safe choice to start with is Long. Use a tool like NetSpot to monitor WiFi network. If all is well and there's no drops, only then I would try setting it to Short. I would be very careful with Short because it can wreak havoc on my WiFi network due to packet retransmissions if one of my clients isn't compatible or has a problem with its WiFi signal.
So you are right, gathering more settings/data is better. It might not help in all cases, but it certainly won't hurt.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@michaelkenward wrote:
Maybe there isn't one. They don't always go side by side, especially for satellites.
Satellites pull their Wireless Settings from the main Router. If there's a misconfigured Wireless setting or any setting for that matter, it will affect all Satellites. Otherwise, common wireless issue is often traced back to the main Router settings unless there's an issue like hardware failure specific that one Satellite, stale configs were still stuck in NVRAM, which requires reset to clear, or weak Backhaul between Satellites/Router.
I would be very interest in any special config that's only configurable via Satellite. That would be nice to know as well. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
@MikeG63 wrote:
A couple of question if I may
- Does re-booting the router also re-boot the satellites?
- Also is there a way to re-boot individual satellites?
Thanks
1. No.
2. Yes, need to enable telnet, then telnet into each Satellite/Router and type "reboot"
Check out this link for telnet and related info.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not quite sure what you are looking for here, but the RBS50Y Outdoor Satellite and RBS40V Voice are two satellites that do wonky things.
The Outdoor Satellite certainly has wifi controls that are unique to its interface. The indoor/outdoor thing is something to do with the law.
As yet, no 2.3.1.60 on the RBR40.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't have those kits and can't really speak to them and I'm certainly not advocating against the law. However, I would be very interest in those Wireless Settings if available. From this Forum/users, some with basic Orbi package, like RBK53, have wireless drop/connectivity problem. Those are the basic setup, which I was referring to in my earlier posts. If we could solve simple/basic setup, it would be a good start.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Tried going to long preamble mode and the result was that my internet speed was cut ion half!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you have WiFi drop before/after as a result of this test?
WiFi speed drop is expected with Long because there's more overhead to transmit, which is the reason for Short. It's a trade off between performance and reliability. GIven you have WiFi speed lost, have you disabled 2.4Ghz co-existent?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Regarding "suffering from WiFi drops with 2.3.1.60", I had between 3-4 drops/day, so I have been in Kamikaze mode upgrading to the latest firmware to improve stability and Wi-Fi speed connections. I was finally lucky to fix my issues with the following:
- Get rid of my NBN service provider router (Optus in Australia) and connect Orbi RBR50 directly to the NBN box.
- Upgrade to 2.3.1.60
- Activate MiMo support at advance setting (is set off by default); I have 32 devices connected to my network so this was relevant for me.
- Disable Disney Circle parental control and leave default Netgear control.
- Scan channels saturation (2.4 & 5.0 GHZ) on my phone and manually set it on available empty channels. My neighbours and I were using same channels in auto mode.
- Reboot Orbi.
I hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
For me, its easy. I run 3 non-default settings in my setup:
1) Enabled Implicit Beamforming
2) Enabled MU-MIMO
3) Use Open DNS servers instead of automatically getting from my ISP.
Thats it. With this setup I've been rock solid on every firmware version since I purchased the system 2 months ago.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Downgraded to 2.3.1.44 and now it is more stable but when connecting to the WiFi with my phone sometimes the connection with internet is failing as well.
Never experienced problems with the Orbi but this is frustrating!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Correct, did a factory reset twice... Didn't solve the problem so downgraded tot 2.3.1.44 and thought the problem was over but now I have internet from time to time but a lot of downtime... Wifi is working, but a lot of internet downtime, and cannot connet with the orbi app (see screenshot).... Hopefully netgear can help....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looks like it is only a wifi problem, have two lan cables inserted (p1 reader and synology NAS) and they have an internet connection... The wifi does not have an internet connection and I cannot go to the settings orbi app and orbilogon.com....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you power cycle the ISP modem off for 30 seconds then back on after you reset the Orbi?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Try the above settings after updateing to v60 and doing a factory reset and setup from scratch.
@Joostvanderpost wrote:
Updated to 2.3.1.60 with RBR50 en RBS50 but connection with internet was lost after approx 30 minutes. Tried Total reset twice without result, also within 30 minutes lost connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
We believe NG disabled AutoUpdate at v32/v44 and beyond. However the system still queries NG update servers and lets users know if there is a FW update available. So from now on, users can pick if and when they want to update Orbi FW thru the FW update feature on the RBR.
@Joboo7777 wrote:
Has anyone received .60 through the auto update process? I’m on .44 and have not received .48 and now .60 through auto updates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Today I spotted a change to my router setting disabling IGMP Proxy. I know I didn’t and wouldn’t have done it, so something touched it. Getting difficult to trust anything. I’d like to see a written policy on update handling. Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Both my RBR50 and RBS50 want to download the latest firmware and have never been able to and TBH it's quite annoying.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you select the RBS first to update?
What browser are you using?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Really don’t know what all the drama is. I logged into the app, it said update available, downloaded and installed firmware, Orbi works just as awesome as it always has. Bravo Netgear....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Lets see what version of FW is loaded first. He may be on a old version which may not work for him until he gets it more up to date or there is a NG service issue or possible ISP modem issue. Lets find out first what he's got going currently.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You're just not reading enough to find the drama in the forum. 😛
- Mark as New
- Bookmark
- Subscribe
- Permalink
2.3.1.48 is the version on both RBR50 and RBS50
