- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Firmware Update 2.5.0.38
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Firmware Update 2.5.0.38
@FURRYe38 Perhaps that would help, but I fear what a factory reset involves. There are many settings, for ports, fixed ip addresses, etc. that would have to be set up again. I am getting pretty tired of these issues with the Orbis!
I see that my ISP sells Google WiFi, 3 units for the price of 2, I am seriously considering this, but I am unsure if they have any HomeKit or other issues to be aware of.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@bjornand1 wrote:@FURRYe38 Perhaps that would help, but I fear what a factory reset involves. There are many settings, for ports, fixed ip addresses, etc. that would have to be set up again. I am getting pretty tired of these issues with the Orbis!
Just revert your firmware and leave it alone
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Orbiman2222 My problem was that even 2.5.30 was a disaster for HomeKit so even that would not help me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I fully understand the frustration of setting up from a factory reset. Many users have different configurations. Once thru the reset, users have to remember that there is the backup configuration to file. This saves time after doing a reset. The reset help clear out any lingering prior FW and mis-configurations. There may some new FW code that makes older FW code or configurations incompatible, thus a reset is needed.
Factory reset is as last resort. however some users don't even give this a try. When users don't at least try this as a last resort and lest us know that they did, then it its frustrating for us, knowing that the reset has help us and others.
Try the reset and when you get the system setup. Do a Backup of the configuration to file. This is a time saver.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you offer phone service?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Roll your firmware back to an eariler version and stop doing manual updates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I searched downloads for my RBK50 v2 system and the only firmware available to download is the dreaded v2.5.0.38. Can you provide a link to previous versions? I performed a complete reset of my Orbi system (as suggested) and the results arent much better, in fact it seems that the wireless range is not as good as it was prior to this latest firmware update and I have encountered some wifi blackspots in my house again. I need to get this back to a workable state, thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If a earlier version is not available on the NG download area, I'm not sure where to look. Maybe other can chime in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have separate SSID through telenet. Doesn't work in the latest firmware.
Why Netgear!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@parostberg wrote:I have separate SSID through telenet. Doesn't work in the latest firmware.
Why Netgear!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
@Alanandstaci wrote:
Ever since i updated, I have had issues with my wifi slowing way down, almost to 10 or 15 when I normally get near 300. Then I have to reboot and it works for a while. Then it happens again. Please help I have the RBR50 V2
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Ever since i updated, I have had issues with my wifi slowing way down, almost to 10 or 15 when I normally get near 300. Then I have to reboot and it works for a while. Then it happens again. Please help I have the RBR50 V2FYI...the OP is: Orbi Firmware Update 2.5.0.38 so why are you asking all of these of questions. Just tell to them to revert their firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? ... What channels are you using? Auto? ... Any Wifi Neighbors near by? If so, how many? .. Has a factory reset and setup from scratch been performed since last FW update?
Agreed. About 12 hours ago I finally did the downgrade to v2.3.5.30. First the satellite, then after I noticed no improvement, did the RBR as well. Since then I'm back to the way things have been for years -- i.e., my laptop hasn't dropped off the wifi a single time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have downloaded the version before this one and tried to install this but it didnt downgrade eventually.
I did this on the website logged on to my orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Raymonddeniet wrote:
Could anyone tell me how to downgrade?
this may help:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any idea when the fix is coming? Been a while since the release of this buggy firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have not detected a "pattern" in Orbi firmware updates. 2.3.5.30 came out in (May? June?). However, this one seems to have been such a "stinker" that a rework will show up sooner. However, MY GUESS is that it still could be months.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So, here's the pragmatic thought - my router works fine, as do my satellites. So the 80 / 20 rule stands, i.e. does it fulfill 80% of my requirements. My network is stable and all my peripherals work fine with no drops and outages, so I ask myself why get stressed over some icons and names. Yes its annoying, inconvenient, not professional, bad QA, and more importantly for Netgear reputation damaging!!!
Absolutely a new firmware version will come along as per Netgear's release cycle, again probably not well QA'd, and may well address some of the issues / concerns and most likely introduce others. So I am keeping a healthy cynicism and from now on will adopt an n-1 approach.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Others are reporting v.38 working just fine. A reset seems to be key here:
Though its a last resort, a reset and setup from scratch does help to clear out any mis-configurations or lingering FW code from prior versions. I manually update FW which includes a reset and set up from scratch. Have not seen problems using this method for each FW update. Users are encouraged to make backup configurations to file as well. Helps save time if resets are needed.
@MikeG63 wrote:So, here's the pragmatic thought - my router works fine, as do my satellites. So the 80 / 20 rule stands, i.e. does it fulfill 80% of my requirements. My network is stable and all my peripherals work fine with no drops and outages, so I ask myself why get stressed over some icons and names. Yes its annoying, inconvenient, not professional, bad QA, and more importantly for Netgear reputation damaging!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Others are reporting v.38 working just fine. A reset seems to be key here:
Bad advice.....NG has reported that this firmware is the root of the problems discussed here. WHY have people waste their time as you suggest?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Couldn't agree more, in my case no reset was needed, just a router reboot after the upgrade. All that is really required is good quality control and a good quality assurance play book / automated procedure. Also STOP tinkering under the hood!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@MikeG63 wrote:Couldn't agree more, in my case no reset was needed, just a router reboot after the upgrade. All that is really eeded is good quality control and a good quality assurance play book / automated procedure. Also STOP tinkering under the hood!
Smart man. Your network and peace of mind thanks you
