×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Orbi Home WiFi System 2 pack
amaraa
Does Orbi support below:
Mobile App
Bluetooth Onboarding
Location Assistant
Speedtest
Device List
Easy Guest Wi-Fi Sharing
Network Scanning
Router-based Antivirus
Firewall Security
QoS (By Device)
QoS (By Application)
Device Activity Report
Parental Controls (Time Restrictive)
Parental Controls (URL Filtering)
Monthly Usage Reports
Auto FW Update
Automatic switchover without interruption
True mesh 802.11s
Seamless WiFi roaming 802.11k, 802.11v, 802.11r
Do not require a phone and email for setup
Pre-paired from factory settings for easy setup
Smart QoS brings excellent streaming and gaming experience
Support Amazon Alexa
MU-MIMO
Auto Path Selection
AP Steering
Band Steering
Beamforming
Could you please send us Hardware information: CPU, RAM, Antennas … etc.
Thank you.
Model: RBK22| Orbi AC2200 Tri-band WiFi System
Message 1 of 7
Guru
Re: Orbi Home WiFi System 2 pack
I don't believe the Orbi doesn't support some of the features you listed,
Location Assistant
Network Scanning
QoS (By Device)
For specs, review here for each model:
https://www.netgear.com/support/product/orbi.aspx
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 7
amaraa
Good day.
We have question for RBK50 .
If we puchase your product, Will a configuration of special feature run?
Do you have the regional restriction in special features?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 3 of 7
Guru
What special feature are you looking to run? Orbi can do different things.
Language is only for the UI for different languages that are supported by NG.
Message 4 of 7
amaraa
Is it possible to give us  Sales contact of Asia region?
Message 5 of 7
Guru
I don't have this information. I would look at NG support site or contact NG support on the phone.
Message 6 of 7
Blanca_O
NETGEAR Moderator
Hi @amaraa
Please click this link to reach support team. You will find several options for contacting support in the provided link.
Blanca
Community Team
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1314 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
