- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi - Internet Connection Issue with Metronet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m suddenly having issues with my Orbi RBR20 connecting to the internet and putting out a WiFi signal. I’ve done power cycles, hard resets, firmware downgrades, nothing appears to be working. Current stats are attached.
Thanks for your help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi - Internet Connection Issue with Metronet
@kgsmethers wrote:I’m suddenly having issues with my Orbi RBR20 connecting to the internet and putting out a WiFi signal. I’ve done power cycles, hard resets, firmware downgrades, nothing appears to be working. Current stats are attached.
suddenly???
has it ever worked.....how long have you had your Orbi?
Firmware.....did you manually update it recently?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
One change that is often recommended is to use one of the public DNS servers rather than the ISP DNS service, such as 1.1.1.1 or 8.8.8.8
This can be done on the Orbi web interface, the "Internet" menu item.
Would you by chance have activated Armor or Disney Circle?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, Power went out last night and then this morning it stopped working. It's been up and running for a few months and I've never had a single issue. I never did an manual update until today when I tried downgrading in firmare (per metronet's suggestion) to see if that would help. All FW updates have been automatic.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So are both wired and wireless connections not working?
What exactly are you experiencing when your connected to the Orbi?
What devices do you have connected?
Does connecting a wired PC or laptop directly to the ONT work?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It appears that just wireless connections are not working. If I plug laptop directly into the ONT it works fine. When connected to the Orbi via WiFi Nothing will loaf and iPhone is saying “no internet connection” in WiFi settings. Then that pop up will go away and it’ll appear to be connected but nothing will load.
On the Orbi mobile app it says that the status is online and will let me do a speed test, but that connection doesn’t push across to any other apps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So wired thru the RBR works aswell?
Do you have RBS connected or just the RBR alone?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@kgsmethers wrote:
@Retired_Member
When power comes back on that can cause a surge
when you say automatic updates you mean no action on your part?....no clicking?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
