- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi MR 2.1 Update 3/23/18
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi MR 2.1 Update 3/23/18
Besure that you preformed a factory reset after loading the beta FW on BOTH router and Satellite. Then set from scratch.
Placement is crucial as well. Mines about 40 feet disstance between the router and satellite.
@srinivas29wrote:Upgraded to the Beta Firmware for both the router and satellite. The satellite is connected to router in 2.4 GHZ and the connection is poor. Any solution for this, other than moving the satellite closer to the router. Satellite is exactly in a floor below the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did for the satellite, I will have to do for the router. By Factory reset i hope you are asking me to hold the reset button on back of the router for 5 secs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What model Obri system do you have? This beta is for the RBR50 and RBK50 systems only.
If you have the 50 system, use IE11 or FF browser to send the FW file. Besure your wired with the Satllite and router when you upgrading FW. DO NOT USE Wireless!!!
@Csanderson0628wrote:
I did try that link to update it but it would not take that update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You need to reset both Router and Satellites for the new FW to take good full effect. Set up from scratch.
@WAPwrote:Was rock solid on .18 firmware. Tried the beta and now the GUI isn't showing the satellites properly. Reset the satellite back to factory and gave it a couple of hours for it to "settle down". That didn't work. Going to reset router and satellite and see if the beta is at least as good as .18
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The beta FW is for #50 models only right now. Other models are on the way. Please be patent.
I have a rbk33
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, 16 hours up time on the new firmware with..
Daisy-Chain Topology enabled
Implicit BEAMFORMING enabled
MU-MIMO enabled
Fast Roaming enabled.
I have the RBR50 and two RBS50s. So far everything is working flawless! *knocks on wood*. I didn't go as far as factory resetting everything, just updated that sats, then the routers. Figured I'd try that before resetting everything. So far so good, no errors in the logs, no issues on any devices. Best stability I've had in months.
- Mark as New
- Bookmark
- Subscribe
- Permalink
YAY!!!
@TrickyTwrote:Well, 16 hours up time on the new firmware with..
Daisy-Chain Topology enabledImplicit BEAMFORMING enabled
MU-MIMO enabled
- Mark as New
- Bookmark
- Subscribe
- Permalink
Running this for almost 12 hours and all is good. For now, every 1-2 min, I see this in the logs:
[DoS Attack: IP Spoofing] from source: 192.168.1.254. Don't see any attached devices to the router or satellite with this IP.
Any idea what this may be?
- Mark as New
- Bookmark
- Subscribe
- Permalink
In my expoerience, the "DoS Attack" warning in the Netgear logs tend to have alot of false positives. For instance, I run my Orbi behind a dedicated firewall that blocks all inbound connection attempts before it even reaches the Orbi at all, and yet the Orbi logs regularly tell me that it sees inbound "attacks", which are not possible. My assumption is that for many of these, the Orbi is just not doing an adequate job of maintiaing connection state tables, and sometimes what it thinks is an inbound attack is simply a valid response to a legit outbound packet.
I'm not sure about the "IP spoofing" message, however. That might be caused by a packet being received from an address that is not "local" to that interface's network. Or, perhaps it's the result of some sort of NAT behavior. I've not noticed that particular one in my logs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had GUI issues (satellites were not showing up as satellites). Reset satellites, didn't fix the GUI issue. Reset router and satellites and now the GUI display is correct.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Been running fine on the 2.1.2.18 firmware, upgraded this morning about 4am and no issues with the upgrade, router, sat or devices. Been running fine so far. Will continue to monitor
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did the upgrade this morning even though I had no issues with 2.1.2.18. My only observation was that after everything had rebooted and the Orbi router was showing both sat's connected, one of the sats had some connectivity issues. I had this exact same problem when I first bought the system so this is not a new problem.
The scenario is that the Orbi connection status shows both sats connected and connection quality good. Devices connected to the Sat-1 have no issues communicating out but devices connected to the Orbi router or to Sat 2 cant reach Sat-1 or the devices connected to Sat-1. Cant ping them, cant get an IP connection. The Orbi is in AP mode so if I use a device connected to the FIOS router I have no issues connecting to both Sat 1 and Sat 2. This seems to be an internal Orbi issue.
I can fix this by either rebooting Sat-2 or rebooting the Orbi router.
I opted to reboot the Orbi router and that fixed the problem in just a few mins. Since then the system has behaved normally.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a 1GBs connection from Comcast which I always get close to over Ethernet. However I never got even close to that over wireless before. My speed improved from 200MBs before to over 320MB/s over wirless after this update. That's over 100MB/sec difference right there.
That's all I'm gonna say for now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just FYI, current wireless technology doesn't support 900+- speed testing. At most you might see 500mb. Too many factors llike client HW, design, connection rates and environment. Hard to see thruput speeds like that on wireless.
@Elywrote:I have a 1GBs connection from Comcast which I always get close to over Ethernet. However I never got even close to that over wireless before. My speed improved from 200MBs before to over 320MB/s over wirless after this update. That's over 100MB/sec difference right there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After running this latest update, here is something interesting.
I am using the Wifi Sweetspots app to test wireless speeds between the device and router. Although I can log in to the satellite and router to see what devices are logged in to each. The Wifi netowrk shown in the app has an assigned MAC address and it does not match up with either the router or satellite. I have read that there are other MAC addresses in the Orbi system.
When the satellite shows my phone connected, I am getting 400-500+ mbps. I assume this is testing the connection between the phone (connected to the satellite) and pinging the router. The interesting thing is, when I am connected to the router, speeds show only 50-80 mbps when I am 10 feet away from the router.
Odd. Can anyone else run Wifi Sweetposts and report back as well?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes seeing same thing with Wifi Sweetspots, ranging from 300 to 400+Mb. I presume this is between device and router only and not ISP services.
Looking at the About info, its seems only to find spots in the room best for your routers and such. So, ya, only between the mobile device and router. Which speed if your close will be high and are also testing max speeds of your mobile device as well.
@mealtowrote:After running this latest update, here is something interesting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oh well, made it 24 hours and connections dropped for multiple devices.
send them back to the room....
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38wrote:Yes seeing same thing with Wifi Sweetspots, ranging from 300 to 400+Mb. I presume this is between device and router only and not ISP services.
Did you try running Wifi Sweetspots while connected to satellite versus router? If so, compare it to my numbers and see where we stand.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@steve8411wrote:Oh well, made it 24 hours and connections dropped for multiple devices.
Out of curiosity, what make, model, type of device(s) dropped?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mealtowrote:Running this for almost 12 hours and all is good. For now, every 1-2 min, I see this in the logs:
That is possibly your ATT Gateway (2Wire or Arris) that is pinging your router. I have the same thing. If your ATT Gateway is set up to block DOS attacks or filter pings then you can disable that on the Orbi (although you should have your Orbi set to DMZ on the Gateway and disable most of the filtering and let your Orbi handle all that).
cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
2 iPads and an android phone..
Personally wondering if there’s an issue with the DHCP from the router when jumping from sat to router and vice versa
- Mark as New
- Bookmark
- Subscribe
- Permalink
@steve8411wrote:2 iPads and an android phone..
Do you have fast roaming enabled?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No fast roaming and no daisy chaining.
Gonna set a static IP on my IPad and see if I lose the connection...
- Mark as New
- Bookmark
- Subscribe
- Permalink
