- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Model RBK50 When syncing the satellite does the light pulse on stay on steady when synced?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having a hard time connecting my robot vac to the internet. and I am wondering if the satellite orbi is synced with the main router. I get a blue color but it is pulsing and not staying on steady. What am I doing wrong. Our tvs are connected ok.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Model RBK50 When syncing the satellite does the light pulse on stay on steady when synced
@AnnieBelle wrote:I am having a hard time connecting my robot vac to the internet. and I am wondering if the satellite orbi is synced with the main router. I get a blue color but it is pulsing and not staying on steady. What am I doing wrong. Our tvs are connected ok.
Here are what the colors mean: https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean . It says:
Pulsing blue and magenta. The Internet connection is blocked because the traffic meter is configured to block Internet traffic when it reaches the limit you configured.
Do you have any traffic limits set on your Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
