Orbi WiFi 7 RBE973
Reply
Orbi Outdoor and cable modem compatibility
9768malcolm
Follower
Does anyone know if the Netgear Orbi Outdoor wifi range extender/booster is compatible with my Netgear CG3000-2STAUS cable modem supplied by Optus?
I have a seperate dwelling about 18 meters from the cable modem position but the signal is weak and intermittent there. I'd like to boost the signal with a wireless outdoor extender.
The Orbi Outdoor looks like the ideal device but I can't find any info on compatibility.
Thanks for any advice.
Model: CG3000-2STAUS (CG3000v2)|Cable Modem. Gateway
Message 1 of 2
CrimpOn
Guru
Re: Orbi Outdoor and cable modem compatibility
Yes, the RBS50Y can be connected to a "non-Orbi" WiFi system.  See the installation guide here:
http://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y_QSG_EN.pdf
This satellite is clearly intended to be part of an Orbi system, but Netgear has no other outdoor rated WiFi units.  So, the RBS50Y has a switch so it can be "Orbi" or "non-Orbi".
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 632 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
