Orbi WiFi 7 RBE973
Reply
Orbi Placement
Jason-8
Follower
Orbi Placement
I want to use this with my tivo mini which needs to be plugged into an ethernet cable, so I have to place the second unit near the tivo which would be about 40 feet from the main unit with one wall between the two.  Can the orbi handle that?
Also when do you expect the release the extra satellite--I would guess I need one extra?
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Placement
Hello Jason-8
Yes this should handle this just fine as for extra satellite that is coming at a later date.
DarrenM
Message 2 of 3
Re: Orbi Placement
hi jason
40 feet is about the optinum distance between router and sat as the backhaul will connect to just about its max at that distance
pete
Message 3 of 3
Discussion stats
  • 2 replies
  • 2883 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
