× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Orbi Port Forwarding
mmarty
Hello!
I'm having trouble logging into my router online to forward a port I absolutely need forwarded by tomorrow morning! I have done it in the past no problem, but have been going around in circles for two hours. orbilogin.com is where I have gone before for the admin login - that seems to have changed completely and I can't get into the back end. It's just a simple customer page. I've also tried the the two recommended IP addresses: http://192.168.1.1 and http:10.0.0.1 - to no avail. Also found orbilogin-com.net but pretty sure that's a scam.
Why can't we just forward ports on the app??
Can anyone help?
Thank you!
mmarty
Message 1 of 4
CrimpOn
Guru
Re: Orbi Port Forwarding
Because the 'app' is not designed to handle any 'Advanced Setup' items.  It cannot forward ports.
On the device you are using to access the Orbi web administration, look in Network Settings to find the IP address of the 'Gateway'.  That will be the Orbi router.  Yes, the default is 192.168.1.1 and if that is not available the router usually selects 10.0.0.1.  The only way to "find the router" is to find the gateway IP address.
On a Windows computer the easiest method is to open a command window and type the command:
ipconfig /all
Message 2 of 4
mmarty
@CrimpOn Thank you for the info - I've just managed to login via 10.0.0.1 on a different computer - I guess perhaps my desktop's firewall settings were too high?
Anyhow - all sorted! Two hours of my life on this...lol. Time for a stiff drink.
Thanks again!
Message 3 of 4
CrimpOn
Guru
More likely something stuck in the browser cache.  Windows firewall is not going to block responses from a browser request.
Speaking of stiff drink.... I'm in!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2985 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
