Orbi WiFi 7 RBE973
Reply
Orbi RB50 won't let me update apps
Blueridger
All,
I bought my RBR50 (and satellite) in November 2018, and installed in a fios house w/o incident. The unit's internet connection became intermittent last night. I reset the unit, and that mostly solved the problem. However, while I can connect to the internet generally, I am unable to update apps on my ipad. Also, the unit is refusing to connect to me Arlo hub, and it requires username/password credentials for many websites.
I had the problem in February and I can't remember how I resolved it. Can anyone help?
BTW, I try to log in to the Orbi through the desktop login site, and receive an error 41 code that demands that I log into the router, then it rejects my credentials.
Thanks!
Steve
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 8
Accepted Solutions
Blueridger
Re: Orbi RB50 won't let me update apps
Netgear somehow created two separated threads out of my question. Here is the response I posted last night after the problem was resolved:
Believe it or not, Netgear customer service solved the problem. The problem was IP address conflict between my router and Fios. I couldn't access the router b/c I stupidly followed their directions to log in (admin/password). It turns out that the password was the new one I assigned to the router. Once I entered that, the unit automatically assigned itself a new IP address, and all was golden.
Thanks everyone!
Message 7 of 8
All Replies
Guru
Is the Orbi system operating in Router or AP mode?
Message 2 of 8
Blueridger
Update: I have the correct password, the router simply is not letting me log in. I am connected to the internet through the router.
Help!!
Message 3 of 8
Guru
Help!!
Message 4 of 8
Blueridger
Netgear helped me solve the problem. I'm set - thanks!
Message 5 of 8
Guru
Please post on details of how they helped you fix this so others will benefit should others have similar problem. Thank you.
Message 6 of 8
Blueridger
Thanks everyone!
Message 7 of 8
Guru
Thanks I saw your other thread just now:
https://community.netgear.com/t5/Orbi/Orbi-RBR50-won-t-let-me-update-apps/m-p/1748605/highlight/true...
Glad the conflict was resolved.
Having a modem with a built in router can be problematic. Why we ask for ISP modem model info. Helps us identify these modems.
Enjoy. Smiley Wink
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2410 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
