- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK22 Keeps dropping internet connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
The rbr20 is wired to my modem and the satellite wirelessly. Firmware is the latest on both (2.3.5.36)
In the last Week, it keeps dropping connection. Either the light is off but there is no internet or I notice it's violet.
I have to keep rebooting and it's driving everyone in the house crazy.
It started when my daughter got an iPhone 11 but that may just be a coincidence. That was the only thing that changed from the time it was working fine and started acting up.
I have circle installed and it also keeps discontinuing the premium subscription. I don't know if that's related though.
Mu-mimo and beamforming are Both enabled.
Fast roaming is disabled.
Hope this gets fixed soon. Driving me nuts
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK22 Keeps dropping internet connection
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
@Mozilla168 wrote:
I set up an rbk22 (Rbr20 + satellite) weeks ago and it worked fine.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
I first turned off the satellite and the main rbr20 unit has been working fine for 24hours now. So it must be the connection to the satellite that is causing the problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please give feedback to the question presented.
- Mark as New
- Bookmark
- Subscribe
- Permalink
-Prolink H5204NK
- 1,980 SF (3 stories. Signals mostly needed in 2nd floor so both router and satellite are in the 2nd floor
- 10 ft
2.4= auto
5 = 48
I can see signals from 2 neighbors when in the ground floor, but none on the 2nd floor where the or is area
Will try these
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
-Prolink H5204NK
This is a modem/ router built in already:
http://www.rivijayaweera.com/public_html/?p=1108
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- 10 ft <This is too close to the RBR. 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
2.4= auto
5 = 48
Will try these
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can't access the modem admin panel because the isp disallow it.
I may have to buy a modem which I can freely configure.
I'll try the other suggested solutions in the meantime.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought a tp-link modem/router to replace my ISP's modem. I set it to bridge mode and things seem to be ok now. I've not yet set up the satellite and will observe the performance today first.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like a problem caused by the ISP modem. Hope the new modem in bridge mode works well for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Like when I watch a steaming movie on the tv, the stream would stop, the loading spinning circle would come in and the movie resumes after a few seconds..
This happened 3x In a span of 1 hour last night.
Funny it never happened with my 5 year old router before shifting to the orbi.
Will continue to monitor.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possible you may have a faulty unit. I would seek to replace it with another if this continues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bought the Orbi in costco last month and have installed it in the Philippines.
Not sure I can return the unit.
I'll try to tweak other settings on a trial and error basis, and hope things get better
- Mark as New
- Bookmark
- Subscribe
- Permalink
