Orbi WiFi 7 RBE973
Reply
Orbi RBK22
Otuis
Guide
Orbi RBK22
I M CONNECTED TO WIFI ON MY IPHONES BUT WHEN I TRY TO CONNECT  A PC OR LAPTOP IT SAYS CAN'T CONNECT TO THIS NETWORK??
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 11
Accepted Solutions
Otuis
Guide
Re: Orbi RBK22
Hi!! I was able to use option 3 and it's working great I was able to use Orbi on all my devices thank you so much for your help!!! @FURRYe38
Message 10 of 11
All Replies
Guru
Re: Orbi RBK22
1. to the left of the "A" key is the caps lock key. please turn it off. thanks
2. What firmware is on the router?
3. What modem are you using?
4. What actual error is it giving you? like "connected, no internet' "invalid password'  whats actually going on?
5. Does it work if you're hardwired into the router?
6. Is this a new problem, was it a new install, or whats all going on?
We're not there to see whats going on so we need more data/details to go off so we can help you.
you can also go to netgear.com/support/   type in your model number and it'll take you to firmware, manuals, install guides, and troubleshooting.
Message 2 of 11
Otuis
Guide
Re: Orbi RBK22
It says invalid password on both pc or laptop firmware is up to date i try to update i have a Comcast Modem and the Orbi is connected to it as I said before I am connected to internet on my iphone thru Orbi
Message 3 of 11
Guru
Re: Orbi RBK22
1. Punctuation. Please
2. What model comcast modem? These details are key.
3. What firmware is it? The latest isn't a number and many times it isn't "the latest" and "the latest" changes.
4. Does a hardwired connection work?
5. Again, did something change? is this a new install? Did it work prior? You didn't go into any more details. I want to help but you need to help us so we can help you.
Message 4 of 11
Otuis
Guide
Re: Orbi RBK22
the Comcast modem it's a  Xfinity XB6-A, it's a new install,
i did the set up this morning now it says can't connect to this network when i try to connect a laptop
Message 5 of 11
Guru
Re: Orbi RBK22
Modem Router Combo units from ISPs. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 6 of 11
Otuis
Guide
Re: Orbi RBK22
Thank you, that makes sense! So i Am probably double NAT now if i disable my Xfinity modem will I be able to watch TV? Probably not right?
Message 7 of 11
Guru
Re: Orbi RBK22
You'll need to contact your ISP to see what option is best for your ISP modem with out TV interuptions.
The easiest method would be option #3...
You can try Option #2 as well.
Message 8 of 11
Otuis
Guide
Re: Orbi RBK22
Thank you so much!! I will try one of those later today I am working from home and I have been a little busy i will let you guys know.
Message 9 of 11
Otuis
Guide
Re: Orbi RBK22
Message 10 of 11
Guru
Re: Orbi RBK22
Glad it's working. Enjoy. Smiley Wink
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1385 views
  • 5 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
