Orbi WiFi 7 RBE973
Reply
Orbi RBK40 cuts my downstream speeds in half
madballneek
Initiate
As the title says, the Orbi RBK40 is cutting my downstream speeds in half (speeds checked by speedtest.net, Bing and Google speed tests and actual download speeds in various applications such as Steam & Battle.net) When I directly connect my PC to my cable modem, I get over 200Mbps. When connected to the Orbi RBK40, I get 100Mbps. I tried doing a factory settings reset, different ports on the router and disabling all QoS features, but the problem still persists.
I am on firmware V2.2.1.210, which is the latest per the Firmware update check tool.
Any help is appreciated. Thanks!
Model: RBK40| Orbi AC2200 WiFi System
Message 1 of 4
Accepted Solutions
st_shaw
Master
Re: Orbi RBK40 cuts my downstream speeds in half
Throughput capped at 100 Mbps often indicates a bad cable or failed autonegotiaton between Ethernet ports.
Try a different cable between the Orbi and the cable modem.
Try a different port on the cable modem (if it has more than one port.)
Log into Orbi's Web interface and check the port speed on the WAN port.  It's under Advanced, LAN Port, Show Statistics.
Message 2 of 4
All Replies
st_shaw
Master
Message 2 of 4
Guru
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 3 of 4
madballneek
Initiate
Looks like it was the cable between the modem and the router that was causing issues.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2729 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
