Orbi WiFi 7 RBE973
Reply
Orbi RBK40 keep disconnecting!!!
htngwilliam
I am on m1 1gbps network and I have a pair of RBK40. The installation went very well. I plug the modem directly into the RBK40 router. The setup went well and internet is great.
However, I keep having disconnection from the main router. Sometimes it just cannot connect. Sometimes it just shows me wrong password but I have no issue connecting previously.
Model: RBK40| Orbi AC2200 WiFi System
Message 1 of 4
Guru
Re: Orbi RBK40 keep disconnecting!!!
What is the Mfr and model# of the ISP modem the Orbi is connected too? Built in router here by chance?
Use a good quality lan cable between the isp modem and router...CAT6 recommended
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
htngwilliam
Thanks. Initially the 2.4gHz channel is set to auto and I change it to 1. Also did a reset and it seems ok. The speed and range is awesome as long as it don’t gets disconnected. Keep my finger cross
Message 3 of 4
Guru
Sounds good. Enjoy.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 553 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
