Orbi WiFi 7 RBE973
Reply
Orbi RBK50 AC3000 Firmware
n3tguy
Follower
My current firmware for both router and satellite is V2.1.2.18
Netgear download page shows the latest being V2.0.1.4
This does not match the numerical increment of past firmware versions. When you try to manually install the V2.0.1.4 it cautions you that you are running a newer firmware than what you are asking to install.
Why is this number lower than previous versions?
Is V2.0.1.4 really in truly the latest firmware version?
If I ignore the warnings for manual installation, will I lose some of the functionality introduced in firmware versions:
V2.1.1.12
V2.1.1.16
V2.1.1.28
thank you,
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Oakserver
Initiate
Re: Orbi RBK50 AC3000 Firmware
The firmware has been rolled back to a previous version due to stability problems introduced in the version of the firmware you are running.
You can continue to use it until netgear sort it out, or you can manually install to roll back.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 839 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
