Orbi WiFi 7 RBE973
Reply
Orbi RBK50 Guest network and Disney Circle
JohnTe
I have a new Orbi RBK50 with a Disney Circle parental control device paired with the main network on the Orbi. The Guest Network is turned on with a number of devices connected to that network. In the Circle iPhone app the devices on the guest network are being listed as part of the Circle network. But, the Circle is paired with the main network, not the guest. So, how are the guest devices bleeding over to the Circle/main network?
"Allow guests to see each other and access my local network" is turned off. The Orbi is in router mode. This problem did not occur with my old wireless router hardware and its guest network. The problem is new with the Orbi. I suspect that I'm overlooking some setting that needs to be set properly, but I haven't figured it out, yet.
Thanks for any pointers on how to prevent guest devices from appearing on my Circle network.
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Orbi RBK50 Guest network and Disney Circle
Hello JohnTe
Under the guest network settings in orbi is the Allow guests to see each other and access my local network unchecked?
DarrenM
Message 2 of 3
JohnTe
Allow guests to see each other and access my local network is _not_ checked. I want to keep guest and main networks completely separate.
Thanks.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1240 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
