Orbi WiFi 7 RBE973
Reply
Orbi RBK50 Tech Specs
massagerbyday
Hello,
I currently use an Orbi RBK50 router and satellite which is connected via ethernet to my ISP router/modem. I recently upgraded my internet package to include 1gbps download speeds. I can achieve these speeds when connected wirelessly to my ISP modem/router but when I switch to my Orbi RBK50 mesh system, I am maxing out at approx 525mbps. The tech specs indicates it should be able to achieve speeds of upwards of 866mbps. Is there a way to achieve speeds close to what my current ISP plan allows with this particular Orbi router?
Message 2 of 3
massagerbyday
Orbi rbk50
Hello,
I currently use an Orbi RBK50 router and satellite. I recently upgraded my internet package to include 1gbps download speeds. I can achieve these speeds when directly connected to my ISP modem/router but when I switch to my Orbi RBK50 mesh system, I am maxing out at approx 525mbps. The tech specs indicates it should be able to achieve speeds of upwards of 866mbps. Is there a way to achieve speeds close to what my current ISP plan allows with this particular Orbi router?
Message 1 of 3
CrimpOn
Guru
Re: Orbi RBK50 Tech Specs
Orbi RBR50 is a WiFi5 router (IEEE 802.11ac). What is the WiFi spec on the ISP router and the device being used to measure speed?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 526 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
