- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK50 connection issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, to clarify, I have one Orbi router and one satellite running firmware version V2.5.1.8. I have a 300Mb/s internet plan and my WiFi speeds are great with my other devices, but the speeds on my iPhone XR are subpar and sometimes plain bad. I'm usually about 20 feet from the satellite and 50 feet from the router while using my phone. I'm pretty positive that the reason for the slow speeds is that my phone is being automatically connected to the 2.4Ghz frequency giving me speeds of 10-30 Mb/s when the 5Ghz connection provides 150+ Mb/s in the same location. Is there some way to only allow my phone to connect to the 5Ghz frequency or anything that may help? Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK50 connection issues
@Jonathan245 wrote:Hi, to clarify, I have one Orbi router and one satellite running firmware version V2.5.1.8. I have a 300Mb/s internet plan and my WiFi speeds are great with my other devices, but the speeds on my iPhone XR are subpar and sometimes plain bad. I'm usually about 20 feet from the satellite and 50 feet from the router while using my phone. I'm pretty positive that the reason for the slow speeds is that my phone is being automatically connected to the 2.4Ghz frequency giving me speeds of 10-30 Mb/s when the 5Ghz connection provides 150+ Mb/s in the same location. Is there some way to only allow my phone to connect to the 5Ghz frequency or anything that may help? Thank you
How long have you had V2.5.1.8. I?
There are known issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
It's the firmware.....why won't you admit it?
