×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Orbi RBK50 issues
aryankanse6
Follower
Orbi RBK50 issues
I’ve had the Orbi RBK50 + 1 satellite for over a year now and I’ve had nothing but issues. Firmware is current for both. Problems are random restarts, long boot up times, spotty coverage.
Tried numerous restarts, firmware flashes, factory resets; no change. Running 300/15 from xfinity.
What would be a viable replacement for this system? I just want everything to work.
Thank you in advance for your time.
Message 1 of 2
Guru
Re: Orbi RBK50 issues
Is the Orbi system operating in Router or AP mode?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883...
You can revert back to stock FW if it doesn't work out for you.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 2
Discussion stats
  • 1 reply
  • 205 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
