×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Orbi RBK52W system
NRWells
Orbi RBK52W system
I am looking to purchase a WiFi MESH system for my church. We currently have a Netgear Nighthawk AC1900 but can't get a signal in the sanctuary due to the distance. I was thinking about purchasing the Orbi RBK52W and place the satellites in a line to get the signal there. Will this work? It is a MESH system but not sure if it will transmit from satellite to satellite to router. Any help would be great.
Message 1 of 5
Guru
Re: Orbi RBK52W system
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
https://kb.netgear.com/000048458/What-is-daisy-chain-and-how-does-it-work-with-my-Orbi-WiFi-System
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 5
NRWells
Ok, but will one satellite talk to the other satellite and then to the router? Is this a true MESH Network? If the signal will not pass from satellite to satellite then this will probably not work for us.
Message 3 of 5
NRWells
Sorry, I just saw the daisychain info. Thanks. Will it do this out of the box or does it require technical setup?
Message 4 of 5
Guru
Yes, if you have them Daisy chained in a line, the traffic flow will go from one RBS to the other then to the RBR.
Example of a Orbi AX system in Daisy Chain:
https://community.netgear.com/t5/Orbi-AX/No-Ability-to-Daisy-Chain-AX6000-two-satellites/m-p/1913199...
Same thing for Orbi AC.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 278 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
