× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Orbi RBR 40 causing 404 errors
RajSearing
Really RBR40 router but that wasn’t on list.
Last week out of nowhere I started getting 404 Wanlan errors when trying to get on several websites. Online advice said to switch to AP mode by going to Orbilogin.com. But I can’t get on that sight because my Orbi WiFi blocks it and gives me the 404 not secure wanlan error. Netgear won’t help me because I bought system in 2018. Which sucks and is terrible business policy since I changed nothing and their product stopped working. Thoughts anyone?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Guru
Re: Orbi RBR 40 causing 404 errors
what modem/gateway do you have?
What ip address is the orbi using? You can use that to log into it.
Easy way to check is disconnect the orbi from the gateway, reboot the orbi and reboot the device connecting to it. Then when both reboot, pull up a command prompt and type ipconfig   that should be the ip address of the orbi that you can log into
Message 2 of 5
RajSearing
I got the up address from my IMac Network settings. If I type into Google browser I get nothing. If I type into safari I get 400 bad request. If I type on command prompt I get command prompt not found
Message 3 of 5
RajSearing
Also. When trying to connect to Orbi. I type in www.orbilogin.net. And the freaking thing BLOCKS that page too. 404 wanlan error and asks for username and password
Message 4 of 5
Guru
What modem/gateway do you have?
Try factory resetting the router to log back in. disconnect it from your modem during setup
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 749 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
