- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Orbi RBR/RBS50 not syncing and connected devices not showing
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR/RBS50 not syncing and connected devices not showing
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you disable Daisy Chain?
@numetheus wrote:
Updated again to the new version. Yep. Problem with the firmware. This time it is only recognizing 7 devices. I should have 19. Confirmed that all of my IP cameras are available, and none showing in the device list. I have two devices wired to satellite and the device list for it shows as blank.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do not see how another factory reset will yield different results because a factory reset was performed after the first upgrade to new version. Although I will try it anyways to settle this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
it won't
leave your FW alone
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@numetheus wrote:
I upgraded again just to test daisy chain setting. I’ve turned daisy chaining off, which caused a reboot. Now it shows satellite is disconnected and 6 total devices. Yet all of my devices connected directly to satellite are working. So clearly the satellite is connected. I’m done with this version now. Going to downgrade. My prognosis is the devs failed at testing. Lol
Now think of all the time wasted. Do not perform manual FW updates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has anybody found a solution to this. I thought everything was working and moved the satelite, reconnected with the blue ring...
Just found a device near the satelite was showing as out of range, checked the satelite on the webpage to see whilst it is conencted, the backhaul is not.
I haver the satelite on the same desk as the base now so i could try and fix this easily... not luck
Tried the steps others have done too without success except for reverting to an earlier FW version. Not sure how to do that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@NJC1 wrote:Has anybody found a solution to this. I thought everything was working and moved the satelite, reconnected with the blue ring...
Go to downloads and enter your model number
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you,
I just tried a router reboot again and the backhaul reconnected this time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As a software dev myself, I’m boggled on how a release like 2.5.1.8 Ever made it out the door.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@-Malux- wrote:
I finally downgraded 2.3.5.30 and solved all my problems.
It's not that surprising that going back to 2.3.5.30 will restore old attached devices behavior. Looking at the release notes and version number, 2.5.1.8 is not an incremental FW upgrade from 2.3.5.30. There's a major change on how 2.5.1.8 deals with attached devices, which can take a long time (days) to rediscover/reconcile those devices on the network, especially when those devices are configured with specific names.
The speed up 2.5.1.8 devices discovery post upgrade, I had to do a hard reset with paper clip to wipe out the old device database/settings and avoid making the mistake of restoring/re-applying the old config file from 2.3.5.30 on 2.5.1.8.
You're right regarding NG FW quality, just check out this thread if you're curious: Firmware-Version-2-5-1-8
- Mark as New
- Bookmark
- Subscribe
- Permalink
What's even more mind boggling is that there are those among us here who are blind and would rather lead us down a fox hole of frustration.
- « Previous
- 1
- 2
- Next »
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
