- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR20 Slow Wifi Speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware:2.3.5.30
Setup: Netgear 1000mbps modem, orbi, orbi sattelite, 8 port switch
We have recently upgraded to 600mbps down from our previous 200mbps down. While wired directly into the orbi or the switch I get speeds close to 500mbps down. When connected to the router with wifi in the same room the speed is only around 100-200mbps. Same speeds with the sattelite. Is there some settings I should change, or is the orbi incapable of going at a faster speed?
I have already tried turning daisy chain on and off, changing dns servers, and updating the router. Attached is a picture of my current settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR20 Slow Wifi Speed
Is the Orbi system operating in Router or AP mode?
Also there is newer v16 firmware available to try...
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is connected to a Netgear CM1000-100NAS modem no router built in. Orbi is in router mode. Approximately 2500 square foot house. Distance between the orbi and the satellite is between two opposite corners of 2 floors. Using auto channel for 2.4ghz and 5ghz. Next neighbors wifi is at roughly 50% within the house. Beamforming and mimo are on. Armor, circle, daisy chain, and ipv6 are already off. I will try adjusting the 20/40mhz setting and the preamble setting and come back with the results.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this issue fixed for you? I am having the same exact problem with similar size home.
@Farhan24 wrote:It is connected to a Netgear CM1000-100NAS modem no router built in. Orbi is in router mode. Approximately 2500 square foot house. Distance between the orbi and the satellite is between two opposite corners of 2 floors. Using auto channel for 2.4ghz and 5ghz. Next neighbors wifi is at roughly 50% within the house. Beamforming and mimo are on. Armor, circle, daisy chain, and ipv6 are already off. I will try adjusting the 20/40mhz setting and the preamble setting and come back with the results.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@SKR2710 wrote:Is this issue fixed for you? I am having the same exact problem with similar size home.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Changing the settings like was recommended did help a little bit but found myself unable to get more than 300mbps unless I was in the same room as the router. I'm convinced it's likely a limitation with wifi ac and the router to put out that kind of speed anything more than a room or 2 apart.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You would be correct in your thinking.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
