× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Orbi RBR20 as VPN client?
As indicated in the subject, is there any way to connect my RBR20 to a VPN as a client?
My current ISP is Cox Cable. They provide a public IPv4 address from which I forward ports to a server on my internal network. The server has dynamic DNS software to update DNS tables if Cox changes the DHCP public address.
I'm testing T-Mobile High Speed Internet. They use CGNAT and their internal network is IPv6 only. I don't get a public IPv4 address and port forwarding is not an option, so I can't connect to my server from outside my local network.
I'm testing TorGuard VPN to create a public IPv4 address that I can forward through a VPN tunnel to the router. My GL-iNet mobile router has an option to set up the router as a VPN client, as opposed to a VPN server. Is that an option with the Orbi?
Thanks for any well-intended suggestions.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 3
Accepted Solutions
CrimpOn
Guru
Re: Orbi RBR20 as VPN client?
Sorry, no.  The Orbi firmware supports OpenVPN Host mode for connecting to the ORbi from the Internet.  It does not support VPN Client mode.
Message 2 of 3
All Replies
CrimpOn
Guru
Message 2 of 3
Thanks for your reply.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1694 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
