- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR20 router - trouble
- Mark as New
- Bookmark
- Subscribe
- Permalink
For the last couple of years I've been using a Orbi RBR20 router and two satellites in access point mode - However , without making any changes, recently the wifi connection is constantly dropping out.
I've checked the wifi provider and the NF18 modem is working well.
- However the Orbi RBR20 router "does not support 802.11AC or newer WoFi technology which limits the range and speed of its signal. An update is recommended.
Please advise how to update the Orbi RBR20 to ensure it works consistently and with max speed
Thanks in advance
Elaine
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR20 router - trouble
@elaine29 wrote:
- However the Orbi RBR20 router "does not support 802.11AC or newer WiFi technology which limits the range and speed of its signal. An update is recommended.
This is not correct. The RBR20 Product Data Sheet clearly states that it supports 5G WiFi, including 802.11a/b/g/n/ac (page 4)
https://www.netgear.com/images/datasheet/orbi/RBR20.pdf
Something has gone wrong, but this is not it. Perhaps some more detail about how the "dropouts" manifest? what is observed? which devices?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks CrimpOn
Unclear what seems to trigger wifi drop out - just that wifi is dropping out continuously: all devices lose wifi: PC, mobile phone; speakers
Have run wifi speeds and they're all good - its just the cut outs
I no longer love my wifi - as its stopping me work and play 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you please confirm the firmware release on this Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
sorry - but how do I find the" firmware release" on the orbbi
ive checked on this site and there's no guide
- Mark as New
- Bookmark
- Subscribe
- Permalink
(My Bad... not thinking clearly).
On the Orbi app, press on the picture of the router to bring up the network diagram.
Then press on the picture of the router.
Then press on "Details".
Firmware version is in the list. Should be a number like V2.7.3.22
Or.... on the Orbi web interface (http://orbilogin.net) the firmware version appears in the upper right of most web pages.
Would you by chance have something that can connect to the Orbi router with an ethernet cable?
(desktop or laptop computer?)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
There was probably a reason for putting the Orbi into Access Point mode. Can you share why that was done?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR20 router - trouble syncing satellite
@elaine29 wrote:For the last couple of years I've been using a Orbi RBR20 router and two satellites in access point mode - However , without making any changes, recently the wifi connection is constantly dropping out.
Thanks in advance
Elaine
I. Am not sure about current firmware installed. Using Orbi mesh router onMac Mini OS 12 2 1
