Orbi WiFi 7 RBE973
Reply
Orbi RBR40 lost its WIFI and won't reset
rrudd
Follower
I've had this RBR40 for about 2 weeks.  It worked great in the beginning.  I'm running 1 satellite.
Yesterday, we lost Wi-fi throughout the house.  I know of no changes that were made to router hardware or settings (does this thing get automatic firmware updates?).
Today I've tried connecting to the router via ethernet cable from my PC.  I'm unable to load the setup which was at 10.0.0.1.  I tried resetting by pressing the reset button, holding for over 1 minute and no change to the green power indicator, so this is also obviously not working.  I've powered it off and on multiple times but it just comes back to the same white light blinking halo.
Thanks for any help you can give!
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Orbi RBR40 lost its WIFI and won't reset
Hello RRudd
This is a known issues with the firmware I suggest contacting support they will be able to help.
http://www.netgear.com/support/contact.aspx
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3178 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
