Orbi WiFi 7 RBE973
Reply
Orbi RBR50 2.7.0.70 not showing all the attached devices
riceale
Tutor
RBR50 (2.7.0.70) and two satelites RBS50 (V2.7.0.70) and RBS20 (2.5.1.16) are not showing all the attached devices in the website or app.  Is this a known issue?  Any recomendations?
Thank you
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 15
Guru
Re: Orbi RBR50 2.7.0.70 not showing all the attached devices
Does same happen with RBS20 turned OFF?
You might upgrade to v102:
https://community.netgear.com/t5/Orbi/Orbi-RBR50-Router-Firmware-Version-V2-7-2-102/m-p/2034115/high...
Message 2 of 15
XBond
Apprentice
The exact same thing is happening to me and I do have 102 (got it today).
It started happening about a week or so ago when I rebooted my router and 2 satellites. Neither the app nor webpage shows all the connected devices.
What's worse, after the 102 upgrade this morning, the app is now acting completely wonky. E.g. on the home screen, the Devices Manager shows 'Devices (10)'. This is incorrect as there are more devices attached. However, if I tap on the Devices Manager to see the details, it now says 'Devices (111)' - huh! There are things on that list that I do not recognize and it is clearly wrong : The website shows 10 connected devices (which I all recognize). In the app, if I tap 'Network Map'  and then tap on my router/satellites, I don't see 111.One satellite is showing the wrong devices (e.g. my wife's phone, but she is not home). And it also shows my phone connected to both the satellite and router!
Both the router and satellites were rebooted this am.
Also, the app used to show devices listed under the WiFi (guest, non-guest) it was connected to - no more. That was really handy. Would be great to get that back.
Message 3 of 15
Guru
I would give it a day to let the system settle in after the reset and you set itp.
If this fails, you might revert manually back to v16.
Message 4 of 15
XBond
Apprentice
I would prefer not to have to do a factory reset/scratch setup and that does seem rather "harsh". Smiley Happy
I will give it a day to see if things shake out. I was seeing similiar issue prior to the FW update, so I am not sure if reverting will help, but it is certainly an option.
Message 5 of 15
vajim
Master
or perhaps revert the firmware
Message 6 of 15
Guru
Factory reset would be needed after the update to ensure any odd problems are cleared out and give the system a clean slate to work with.
Message 7 of 15
vajim
Master
Not true
Many users here have done firmware updates without performing a factory reset, which by the way is more so used in cases of lost passwords.
Message 8 of 15
Happyrocks
I am having the same problem. I can only see a max of 16 devices which makes it difficult to troubleshoot an issue I am having with a camera because I can't see where it is connecting to. I haven't tried a factory reset as I am not sure this will fix the problem and don't want to waste time re-setting everything up.
Message 9 of 15
XBond
Apprentice
I was finally contacted by Netgear support and although it took quite a while and several screenshots, I was able to help them understand the issue.
My hunch is that this was a feature change at some (recent) point, and I requested that they at least added options to the app to turn this functionality off.
Message 10 of 15
vajim
Master
Stop using the app.....junk.
Message 11 of 15
Guru
You can try updating FW as well:
https://community.netgear.com/t5/Orbi/New-Orbi-RBR50-Router-Firmware-Version-V2-7-2-104-Released/m-p...
Message 12 of 15
vajim
Master
These updates may be the cause of the problem
turn off pushing updates
Message 13 of 15
Happyrocks
Get the same result in both the router GUI and the app. I generally don't use the app.
Message 14 of 15
Guru
Try udpating to v104:
or downgrade to v16:
https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/tru...
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 2028 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
