× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Orbi RBR50 Basic screen, unable to see satellites and attached devides online
clubshred
Tutor
I logged in to see to check for updates and noticed that on the Basic home page attached devices, no satellites or attached devices are shown. Normally I have 3 satellites and 33 attached devices. Why are they not shown? No router updates were done, only IOS update for my iPAD and it does show 3 satellites but no attached devices. I have rebooted my PC and my iPAD and no change at all. Any thoughts or help would be greatly appreciated.
RBR50 Router
3x RBS50 satellites
current firmware version V2.1.2.18 on all Orbi devices
PC running Windows 10
iPAD running 11.2.6
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only), RBS40| Orbi AC2200 Tri-band WiFi (Add-on Satellite)
Message 1 of 6
DarrenM
Sr. NETGEAR Moderator
Re: Orbi RBR50 Basic screen, unable to see satellites and attached devides online
Have you checked this with both the app and the web gui to see if it maybe a display issue?
DarrenM
Message 2 of 6
Guru
You might try updateing to the Beta FW and see if this changes anything.
Message 3 of 6
clubshred
Tutor
Thank you for your reply, however I’m not sure what a Beta FW is and how do I find it and or configure it?
Thank you again!
Message 4 of 6
clubshred
Tutor
Thank you for help!!
I have heard that Windows 10 can sometimes be an issue with certain programs. I remember there was a remedy for that in the display properties. I will try and if it fixes it but I think it would affect the whole program and not just a single item within the GUI.
But you never know, but I will try.
Thank you again!!
Message 5 of 6
Guru
Try using different browsers as well, IE11, Opera or FF.
You can find the links to 50 series beta FW here:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/td-p/1533584/jump-to/first-unread-m...
Be sure that after you install this Beta, please perform a full factory reset on both Router and Satellite and set up from scratch to be sure the new code gets installed well.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 999 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
