- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 Extender Compatibility
- Mark as New
- Bookmark
- Subscribe
- Permalink
In 2018, I bough an RBR50 with two RBS40 extenders. With all the work from home in my future, I want to add another extender. It seems very hard to find any extenders compatible with this setup that are available to ship.
- Do any other non-Orbi Netgear extenders work with this system?
- Am I better off scrapping this system and starting from scratch wit a new router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 Extender Compatibility
Would be best to get another RBS or RBW.
I've heard that the EX3700 and 7700 work however you have to contact NG support and ask for FW to make them work. They don't out of the box I believe.
Why do you think you need another extender? Having dead zones in your home?
Is there a problem?
I
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes - my home is a ranch with a second story and one side of the house is a dead zone. I have the Orbi hub plugged into the Verizon router in the middle of the first floor, a satellite on the first floor on one side of the house and another satellite upstairs in the middle of the second floor. I am looking to add a satellite on the first floor on the other side of the house. All of the satellites are out of stock everywhere.
My RBR50 has firmware version V2.3.5.30
One Satellites has that firmware version and the other has firmware version V2.3.5.32
- Mark as New
- Bookmark
- Subscribe
- Permalink
v30 on the RBR? RBR and RBS should be on same version of FW.
Can you move any one of the RBS nearer to the deadzone?
What is the distance between the router and satellite(s)? 30 feet is recommended or more in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Happen to have a layout example of your home?
Trying to see if maybe we can use what you have to get you signal coverage on the dead zone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
House is 5000 Square feet and very long from end to end. If I move one of the satellites, I will just have a different dead zone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If it's a long house you could possibly do a Daisy Chain, however that might be moving the RBR.
I have same size home, rectangular as well mostly. 2 story with basement. However my modem and RBR are up on 2nd story at one end and the RBS is down the basement, wireless or wired. about 30-40 feet away. I do have a 2nd RBS in a 1st level dining are thats off to one side towards the back of the house. Its about 25-30feet as the crows flys.
I guess since your RBR is the the middle that you have the RBS on either side of the RBR?
You can try a EX3700 or EX7700. Something to ask NG support about getting FW to make either one of these work. IF these are in stock someplace.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tough to measure the distance because there ae a lot of walls! I really think I just need another satellite, but I can't find them for sale anywhere! That is why I was thinking a generic extender.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Buliding materials will be problematic for satellites and extenders as well.
You might try something and see if it will connect. if it doesn't then return it. Find a place with a good refund policy.
