rando_man
Oct 08, 2019Follower
Orbi RBR50 Windstream Connection issues
Windstream ISP w T3200 ISP-provided modem. Orbi setup went smoothly, but the Orbi WiFi network randomly goes offline and requires a reboot. I can switch to Ethernet to modem or the T3200 WiFi and I have connectivity. I have not entered ISP login credentials to the Orbi setup. Recommendations on Orbi or Windstream modem setup configuration before I just bag it and return the Orbi.
1 Reply
If your modem already has a built in router and wifi, it's best to disable WiFi on this modem.
Try one of the suggestions here:
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try #1 first if you can. If not, go for #2.
rando_man wrote:Windstream ISP w T3200 ISP-provided modem. Orbi setup went smoothly, but the Orbi WiFi network randomly goes offline and requires a reboot. I can switch to Ethernet to modem or the T3200 WiFi and I have connectivity. I have not entered ISP login credentials to the Orbi setup. Recommendations on Orbi or Windstream modem setup configuration before I just bag it and return the Orbi.
