Campiej8855's avatar
Campiej8855
Follower
Jan 11, 2020
Orbi RBR50 and Beyond - Do the newer Orbi models provide relief for ATT users?
I have an Orbi RBR50 with the AC3000 Router. The only way I could originally get it to play nice with my ATT Modem was to use the Orbi in A/P mode. However, the functionality of the router is limited in A/P mode as I am unable to use Circle or Armour.
Can any of the newer Orbi models function as a modem/ router so I can ditch the A/P mode and use Circle?
Thanks
1 Reply
  • FURRYe38's avatar
    The only Orbi model that works as a modem/router is the CBK40 that has a built in modem.
    The Orbi AX doesn't have a built in modem. Not sure if NG will be doing this. They only have The Orbi 8 series routers which work as routers or in AP mode.
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
    You can try option #2...
    Thanks
